I cannot find the Object Enabler for ASD 2013. Can someone supply a link please. If someone is in the know, with the OE will I then be able to open a ASD2013 drawing with model space object and layout tabs showing the same as if I had opened with ASD? Just making sure.
Solved by DarrenP. Go to Solution.
i found it: http://knowledge.autodesk.com/support/autocad/downloads/caas/downloads/content/autocad-structural-de...
DarrenP
