AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
ASD 2013 - Limited number of layout tabs?
3 REPLIES 3
1286 Views, 3 Replies
I am able to create up to 5 tabs per model and file, but if I try to create another layout, I lose a layout tab or two.
3 REPLIES 3
You did't lose it...  Look in your "printouts" tab in the object inspector.  If you aren't using the "object inspector" you will have a tough time in ASD.
Many thanks. I am using the Object Inspector. I can see the Prinouts, but the number of Layout tabs is limited. I can work around this, but it does not seem necessary to limit the number of layout tabs.
Scrambled
I found this bit of information-
type-- setpbuf in the command line.  Change the 5 to 30.
now you get 30 views.
Steve
”Boost
”Tips
