When you design your Rc beam, use the Objet Inspector, select your beam in the tab Model, right click and "Create 3D view" .
Cheers,
Hi! I am using ASD 2013 and modeling a foundation slab (reinforceing it) - when I do the option you've mentioned in a post above I only can see the formwork of the slab without reinforcement - how to make it visible?
I also created some basic elements with the help of a tab ASD - Structure Elements -> (Panel) Structure Elements Reinforcement: Beam, Column, Spread footing - and every option from this list I could visiolize in 3D and COULD see the reinforcement.
It doesn't show me the option of 3d view, just some reinforcement table options. What should I do? This would be the only way to get a 3d view?
