I installed the trial version of Advance Concrete 2015 and I am very disappointed. The program is way behind to ASD for reinforcement drawings.
It does not exist a discussion for Advance Concrete. Has anybody tried this software?
Solved by zcsillag. Go to Solution.
Hi Redli1,
I have worked with Advance Concrete.
I could help you with any questions you may have.
Please let me know
I don't know that much about Allplan. Haven't worked with it.
I do know about Advance Concrete 🙂
Cristina
The Advence Concrete has bug? Works well?
The detailing and design generated autimaticos are good?
The module has Advence Concrete for precast or prefabricated?
Thank you
I did both precast and cast in place details with Advance Concrete.
You can try it and if you stumble upon something you don't understand you can ask me
Hello !
I`ve got a proble with the reinforcement drawing.
When I create one from the 3D model and leave the 3D power turned on, everything works fine. The 3D power forks fine.
But, when I close the program and (lets say on the next day) reopen the drawing and trying to continue the work, the 3D power doesnt work anymore.
What coul be the problem?
(Its not a trial version)
please is it possible to do rebar surface reinforcement for slab detailing in advance concrete? This feature is available in ASD but i can not find it in advance concrete. I don't want to use mesh.
Hi. Is there any way to make reinforcement section non perpedicular to WCS?
Thanks.
Could you please tell me how to create the list?
I have tried modify existing list by added column and variable, but the total weight changed, sometime disappeared (ex. <sum(col[...])>).
Could you please send me the file and also tell me which version are you using? 🙂
Cristina
I can't see the attachment. Could you please send it to my email address: cristina.jianu@autodesk.com? 🙂
Cristina
Cristina
buen dia, envio informacion espero solucionar tu problema
