AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Adding Triangular Plates and Other Questions
1 REPLY 1
RogerZimmer
515 Views, 1 Reply
What is the procedure for adding plates to an ASD model when the plates are not circular and not square?
also . . . the attached screen shot shows my default dialog box when I activate the plates command in ASD modeling ribbon.  It always defaults to a 10" plate, no matter how many times I insert a plate.  Also the dialog box only seems to recognize / default whole numbers, 1,2,3 etc, no decimals.
I suspect this has something to do with inch to millimeter conversion(s).  Anybody have any ideas?
1 REPLY 1
edugarge
in reply to: RogerZimmer
Please, you must read the manual. It has all the answers to your questions and more!
(You can find it in your own PC... C:\Program Files\Autodesk\AutoCAD Structural Detailing 2011\Setup\es-ES\SetupRes\InfoLink\...)
Chapter 2.1.3 Units (defining units, metric, imperial, etc)
Chapter 7 Plates (user defined plates, like polylines > triangular)
There are Tutorials and some Getting Started Guides.
Try them.
”Boost
”Tips
