AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Adding Templates Via Objects Inspector
6 REPLIES 6
tpham2001
1168 Views, 6 Replies
Hi All,
Hoping someone can show me the way.
In Object inspector under Position Tap, if you right-click on a position and select Attach Document a dialog box appeared with a list of templates you can choose from. How do I add or assign more templates to this dialog box?
Please see file attached.
When I right-click and select Attach Documents, the Select Tamplate dialog box appeared and only contain assembly tamplates. How do I add/assign ISO view tamplates to this list?
Thank-you,
Tee
6 REPLIES 6
talles.projetos
in reply to: tpham2001
Do the steps given below. ok? You do this to assembly. ok?
zcsillag
Regards
Csillag Zoltán
tpham2001
in reply to: talles.projetos
Hi Talles,
Thank-you for response along with the attached image, this helps a lot.
Unfortunately, I tried your method and I still unable to add/assign additional tamplates in "Select Template" dialog box.
Tee.
tpham2001
in reply to: zcsillag
Hi zcsillag,
Thank-you for your response along with attached image, this help a alot.
Now all I have to do is to this for all my tamplates, from detail -> assembly...
The attached image might be confusing for some, because I added ISO NW view after I ran "Automatic Drawings" and simply "Attach Document, then select Assembly again. But if I were to delete all the documents and runs "Automatic Drawings" again, I'm sure my ISO NW would be there.
Thank-you for the resolution.
Tee
zcsillag
Make templates with ISO NW, not 3D user view 😛
When ur 3d modell top view, 3D user view same 😄
Regards
Csillag Zoltán
tpham2001
I used Iso NW when I added view, my screen shot was an attempt to show that your method does works.
As I go thru my list of templates and adding ISO views as needed; I noticed I caould not do the same for Engineering Scheme. I can not add views to this template; have you run into this issue? Thus far, all my Engineering Scheme are shown in Top View; wouldn't it be clearer to show it in ISO view when you have transition from one floor plan to anther?
”Boost
”Tips
