AutoCAD Structural Detailing General DIscussion
Member
RogerZimmer
Message 1 of 2 (679 Views)
adding holes into plates in ASD
679 Views, 1 Replies
02-01-2011 08:29 PM
I am building a model in ASD consisting of HSS tubes and plates.  I have been able to cap the ends of the HSS with plates using the UCS and plate command in the modeling ribbon.
How do I accurately insert a hole in a plate?  I want to put the center of a 0.563" diameter hole exactly 0.75" inside two edges of a 4.25" x 2" x 3/8" plate.  My snaps only appear to attach to the work frame not the plate.  Apparently, I can't even snap a line off the corners of the plate, to locat the hole.
Any body have any ideas?
edugarge
Message 2 of 2 (666 Views)
Re: adding holes into plates in ASD
02-02-2011 03:49 AM in reply to: RogerZimmer
Check out the screenshot I attached. It's from the steel manual of ASD.
After you activate the snapping options, you could use the hole's tools better.
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
