AutoCAD Structural Detailing Forum
Welcome to Autodesk’s AutoCAD Structural Detailing Forums. Share your knowledge, ask questions, and explore popular AutoCAD Structural Detailing topics.
Adding a detail view
8 REPLIES 8
Message 1 of 9
9431 Views, 8 Replies
Hello.
I am trying to get a detail view of a construction im making. Its a truss bridge and i would like some details of some specific parts, for example the connection to a tower its bolted to.
I am trying the DETVIEW command in 'edition layout' but when i go through the command it ends up with saying "Application ERROR: There are no viewports avaliable to create Detail view".
Am i making something wrong, can you not make detailed views of a created drawing? Or how do i make an viewport available?
Thanks!
8 REPLIES 8
Message 2 of 9
Also, using the 'ADDVIEW' command doesnt work either. When i choose what i want with first and second corner the program addes the whole structure to a new view, just zoomed in on the place i choose. To make it more frustrating it resets all my measurements done to the structure in the edition layout.
And the 'ADDETAILVIEW' command does basicly nothing. I choose what i want to see with first and second corner and it just creates a few lines and some measurements. When i try to adjust the style under the view created it shows the whole structure again and deletes the original view.
Is there anyway i can just "rectangle" in the area i want as an detail in a bigger scale?
Message 3 of 9
to add a detail view, you have to first create the "document" with the detial view available.  Let say that you took your model and did a group on it, now to create the documents with the group, you right click, attach document.  Those views listed, none of them have a "detail" view out of the box.
First, click on the Templates layout tab at the bottom of the screen
From the inspector, goto the Templates Tab and find Group - top view (or side view etc), double click it to make it active (yellow) and then expand it out.  Inside there you will see Top view only (for example) and the drawing screen will update to show a single viewport
Right click on the Group -top view, and click add view
From the dialog, select Cross-Section/Details view., give it a name, then click OK.  This will add a new viewport, ready for you to position, to the template.  Add as many as you need.  Word to the wise, try not to overlap them.  Resize them as needed.
Once you have all your view in place, go back to the Edition layout, and add a new document using your new template (Group - Top View) and you'll notice that the original still populates, but now you have open slots to do the other views.
Let me know if you have any other questions, or if anything doesn't make sense.
KP
Message 4 of 9
Great answer, Thanks alot! I did find it out by myself but marked for solution.
Message 5 of 9
Sorry to drag up a 6 month old thread but I am having some problems creating a section view.
I follow how to add documents and create templates. The problem is when I attach a document and use the new template I created with a "Cross Section/Details View" view in it the viewport is blank and has nothing in it. It doesnt matter if I have a Top and Front view or not.
How do you define where/how the cut is made?
I must be missing something-
Jess
Message 6 of 9
Jakub.Brozonowicz
Here.
Any doubts?
Jakub Brożonowicz
Global Product Support
Message 7 of 9
in reply to: Jakub.Brozonowicz
Awesome Jakub.
Thank you!!
Jess
Message 8 of 9
muleman1
Kyle , I cannot generate these details. I must be missing something in your instructions. I have tried for 3 hrs now. What could I be missing? Please reply...
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
Message 9 of 9
Thank pro
Please guide me as screenshot for adding view
Thank pro so much
”Boost
”Tips
