AutoCAD Structural Detailing General DIscussion
Active Contributor
1 Kudo
Post 1 of 4
A workshop drawing of all Angle plates - Filtering
507 Views, 3 Replies
03-22-2013 04:03 AM
Possible to have an assembly drawing without displaying the angles plates ? A worhshop drawing containing all angles plates only ?
For the first part , what you mean ; that is when auto drawings in the position tab (object inspector ) to have the parts selected with at the top header having profiles and part too selected ?
you should only select Part Profile (p) and Plates (pl) on Position of Object inspector.
then do Auto Drawing of those selcted, but take note of changing the Mode to (Many position) System will then arrange Plates in one page and profiles on separate page.
Valued Contributor
9 Kudos
Post 2 of 4
Re: A workshop drawing of all Angle plates - Filtering
03-22-2013 04:30 AM in reply to: Delvin.Ramassami
THEmost useful feature of ASD, yes you can.
when you start you automatic Drawings,first choose parts/profile you want to make auto drawings including plates
ASD will arrange plates in 1 or more drawing and then Profiles detailed.
and Auto'drawings dialogue box, > Arrange Views> Mode, Select Multiple Possition. and generate Drawings.
I hope it helps sort your problem?
Active Contributor
1 Kudo
Post 3 of 4
03-22-2013 05:01 AM in reply to: Delvin.Ramassami
Valued Contributor
9 Kudos
Post 4 of 4
03-24-2013 10:57 PM in reply to: Delvin.Ramassami
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
