Possible to have an assembly drawing without displaying the angles plates ? A worhshop drawing containing all angles plates only ?
THEmost useful feature of ASD, yes you can.
when you start you automatic Drawings,first choose parts/profile you want to make auto drawings including plates
ASD will arrange plates in 1 or more drawing and then Profiles detailed.
and Auto'drawings dialogue box, > Arrange Views> Mode, Select Multiple Possition. and generate Drawings.
I hope it helps sort your problem?
For the first part , what you mean ; that is when auto drawings in the position tab (object inspector ) to have the parts selected with at the top header having profiles and part too selected ?
you should only select Part Profile (p) and Plates (pl) on Position of Object inspector.
then do Auto Drawing of those selcted, but take note of changing the Mode to (Many position) System will then arrange Plates in one page and profiles on separate page.
