AutoCAD Structural Detailing General DIscussion
New Member
dreato
Message 1 of 3 (343 Views)
3D Model drawing
343 Views, 2 Replies
08-27-2009 05:52 AM
Hallo
Who of yours how to know to create a 3d model drawing with ASD Steel. I had found the option to create a schema but this schema is only in one view. I need drawings of my 3d model of all views.
I hope anbody can help me.
Thanks Edited by: dreato on Aug 27, 2009 12:55 PM
Valued Contributor
neil.fernandes
Message 2 of 3 (342 Views)
Re: 3D Model drawing
08-29-2009 10:22 PM in reply to: dreato
Hi Dreato,
I am not sure if I understood you correctly. I believe you have create a steel model and need to create an isometric drawing?
In ASD Steel module. start the group command[Groups panel]. Select all the steel objects you need and press ENTER. Input the name for this group and ENTER. If you did this correctly. In object Inspector, Position Tab you will see the group listed with same name. Select it & right Click and select Attach Documents. You get a new dialog box allowing you to select type of drawings. here you have various options for isometric drawing position and scale.
If you were askin to create a 3D model steel structure, then you need to use commands like workframe, profile, plates, connections, etc...
read the getting started guide that can be downloaded from Autodesk website: http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=13111928
Hope this is helpful.
NEIL
New Member
dreato
Message 3 of 3 (343 Views)
09-02-2009 06:27 AM in reply to: dreato
thank you for your help
New AutoCAD Structural Detailing Category!
The AutoCAD Structural Detailing forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
