AutoCAD Raster Design Forum
Unable to insert MrSID
4 REPLIES 4
KASIKI13
286 Views, 4 Replies
Raster Design 2005 crashes anytime I try to insert a MrSid. I get the following error. FATAL ERROR: Unhandled Access Violation Reading 0xf9f3000 Exception at fc803f8h. Anyone know of a solution?
4 REPLIES 4
in reply to: KASIKI13
Did you send a crask report to Autodesk? Are you doing a "quick" insert, or you transforming the image in some way? Since many MrSidds insert correctly, it may be the particular image you are inserting. On Mon, 17 May 2004 15:22:41 GMT, KASIKI13 wrote: >Raster Design 2005 crashes anytime I try to insert a MrSid. I get the following error. FATAL ERROR: Unhandled Access Violation Reading 0xf9f3000 Exception at fc803f8h. Anyone know of a solution? Phil Daley
KASIKI13
I have sent a crash report multiple times when it has happened.
This particular Mrsidd is a transformation of scale and location. It is also the same set up that has been used multiple times with past versions of Raster Design. Another user in my office is also having the same problem.
I also don't get a fatal error every time I try it, in most cases ACAD just freezes up.
Thanks for your response,
Ryan
Try using the Map menu, Image Insert instead of Raster Design's Insert command. John "KASIKI13" wrote in message news:15675762.1084807391529.JavaMail.jive@jiveforum2.autodesk.com... > Raster Design 2005 crashes anytime I try to insert a MrSid. I get the following error. FATAL ERROR: Unhandled Access Violation Reading 0xf9f3000 Exception at fc803f8h. Anyone know of a solution?
Sorry, I am assuming you have LDD/ALD. John "John Mayo" wrote in message news:40b3ade3$1_2@newsprd01... > Try using the Map menu, Image Insert instead of Raster Design's Insert > command. > > John > > "KASIKI13" wrote in message > news:15675762.1084807391529.JavaMail.jive@jiveforum2.autodesk.com... > > Raster Design 2005 crashes anytime I try to insert a MrSid. I get the > following error. FATAL ERROR: Unhandled Access Violation Reading 0xf9f3000 > Exception at fc803f8h. Anyone know of a solution? > >
”Boost
