Phil,
Some additional info as I am having this problem also. Networked,
side-by-side install w/LDT2004, civil, survey, raster on both 2004 & 2005,
running on XPpro. Applied the contents of the readme file prior to install.
Everything worked on 2004, insert, transform, finish and the image is there.
I saved the dwg and opened in 2005, the image is there. Try to insert the
next image, exactly the same results as Kevin.
The one thing that comes to mind is the readme path info. Are users
supposed to add the RD file path info in 2004 and remove the path for RD in
the environment variables? I'll probably try that in the a.m. if I don't
see anything else here by then.
Thanks for your time,
Pat
"Phil Daley"
wrote in message
news:ppuha0dnu2m7pp1imgdlhcpeshnm58rvlk@4ax.com...
> On Fri, 14 May 2004 10:39:07 -0500, "Kevin"
> wrote:
> >I am having a problem transforming *.sid images (during the insert
command)
> >since upgrading to RD 2005. When I choose the image to insert, the
bounding
> >box is shown on the screen, it moves when I choose my image coordinate
> >system, same as it used to, but now when I click ok to insert the image,
the
> >command line says "Performing Coordinate Transformation" and then nothing
> >gets inserted. If I go to the image manager, nothing shows up there, it
is
> >like the command dies in the middle of the process. I can insert a *.sid
> >file with no transformation, and I can transform other image type (Tiff,
> >Jpg, etc.). Is this a bug, or is this a something that is intended to be
an
> >"improvement"?
> Yes, this is a bug. Thanks for reporting it.
> Phil Daley
