AutoCAD Raster Design General Discussion
Member
bragone
Message 1 of 4 (1,341 Views)
Shift + left click ACAD 2010
1341 Views, 3 Replies
05-05-2009 10:20 AM
I am using shift + left click to make multiple grips hot in ACAD Raster 2010. When I am doing this over an image, it trys to select an image even though I have it turned off in the image options dialog box. Is this a bug?
*Robert
Message 2 of 4 (1,341 Views)
Re: Shift + left click ACAD 2010
05-15-2009 02:41 PM in reply to: bragone
Same problem. I think (hope) there will be a hot
fix soon on this.
I
bug?
Active Contributor
pcedillo
Message 3 of 4 (1,339 Views)
06-17-2010 09:54 AM in reply to: bragone
MAPIOPTIONS>GENERAL>deselect SHIFT-LEFT-CLICK-IMAGE -SELECT
*Expert Elite*
troma
Message 4 of 4 (703 Views)
01-31-2012 09:36 AM in reply to: pcedillo
Thank-you thank-you thank-you!
I couldn't use shift-click to deselect objects or to switch my TRIM/EXTEND command, even though I unloaded the image in the x-ref manager.  Is that a bug?  Who wants to try to select an image while a command is running, or select an image that's unloaded?  Anyway, thanks.
Credit where credit is due! Give kudos or accept as solution whenever you can.
Announcements
Need installation help?
New AutoCAD Raster Design Category!
The AutoCAD Raster Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
