AutoCAD Raster Design Forum
Shift key with Raster Design
3 REPLIES 3
576 Views, 3 Replies
deos some of you had experiment a promblem with shift key to select multiple
grips or unselect object ?
JP
3 REPLIES 3
I believe the shift-pick combo will select the image if you pick inside it's
boundary. This does allow you to select an image without zooming out so you can
see it's boundary but it does conflict with other uses of this combination.
_____________
Karl M. Fuls PLS
AEC Training and Consulting
Assistant Moderator - Autodesk Discussion Forums
Please state the version of your software and the operating system you are using
to facilitate better replies.
JP Trudel wrote:
> Hello,
> JP
This can be controlled through the options in RD. Go to Mouse Settings on
the User Preferences tab.
Allen
"Karl Fuls" wrote in message
news:3F4B0894.F216C34D@adelphia.net...
it's
you can
combination.
> _____________
> Karl M. Fuls PLS
using
> JP Trudel wrote:
> > Hello,
multiple
> > JP
Thank's
JP
"Karl Fuls" a écrit dans le message de news:
it's
you can
combination.
> _____________
> Karl M. Fuls PLS
using
> JP Trudel wrote:
> > Hello,
multiple
> > JP
”Boost
