AutoCAD Raster Design Forum
Rubbersheeting doesn't work - attn. Phil Daley - Autodesk
0 REPLIES 0
Message 1 of 1
380 Views, 0 Replies
Phil, I have posted 2 files: Before.cal and After.cal example files of the distortion in Autodesk.autocad.customer-files. All the LD2005 stations in office produce the same error while rubbersheeting. We used triangular rubbersheeting in this example but polynomial method yields the same error. Before.cal - raster before rubbersheeting After.cal - raster after rubbersheeting, 4 anchor points at 4 border corners 2 anchor points at North and South end of line labeled 97.37' 1 source - destination point at the East end of line labeled 125.18' 1 source - destination point at the East end of line labeled 124.17' Requested shift at the 2 source - destination points was no bigger than 1% of the length of entire raster image in this example. We tested much smaller shifts with exactly same very bad, unacceptable result. We had to switch entire office back to LD3 where rubbersheeting works. Any help will be greatly appreciated, Przemek Panek
0 REPLIES 0
”Boost
