AutoCAD Raster Design Forum
Reprojecting
0 REPLIES 0
Message 1 of 1
401 Views, 0 Replies
Reprojecting
Good morning,
We are experiencing a critical issue with Raster Design 2011 while inserting aerial images in both jp2 and sid formats.  First we set up the dwg using Autodesk Map 2011 in NAD 83, SPCS, Tx South Central, US Survey Feet.  Then we try to insert the jp2 or sid file with a projection of UTM 83, Zone 13N, Meters.  We then tell Raster we would like to translate from the image file coordinates to our dwg coorinates.  Upon telling tell in the insert wizard to finish the program goes unresponsive and remains unresponsive until using the task manager to abort the application.  We can insert the same files without any problem if we do not try the translation.
Also, we can insert and translate a USGS DOQ tif file without any problem.  All of the file types are similar in size and have been retrieved from various sources to eliminate one or more files being corrupt.
Any help you can provide would be greatly appreciated.
0 REPLIES 0
”Boost
