And you can select a portion of the image to adjust. You don't have
to adjust the entire image.
On Tue, 22 Jul 2008 18:44:11 +0000, ErikR <> wrote:
>With using Raster, you have 2 different options. You can use the "Image Adjust" (select image then rightclick--->image--->adjust) to adjust the brightness, contrast and fade or you can use "Histogram" (image--->image processing--->histogram) to modify additional color options.
Phil Daley
