AutoCAD Raster Design Forum
Raster Image Frame Do Not Plot
3 REPLIES 3
PQuick
11351 Views, 3 Replies
How do I make the raster image frame not plot? If I turn off or freeze the layer the intire image goes away.
3 REPLIES 3
in reply to: PQuick
Can't you just turn off the frames with IFRAME?
Matt
wrote in message news:6352420@discussion.autodesk.com...
PQuick
in reply to: PQuick
I found through a google search- the command is "imageframe." Settings 1 for on and 0 for off.
SrealMcCoy
in reply to: PQuick
If you are 2006 or later you can also use imageframe = 2. Image frame shows and is selectable but does not plot.
Patrick
”Boost
