AndyWalker wrote:
> I remember ages ago using Raster for directly editing tiff files and
> you were able to basically click a button and it turned the whole
> drawing (all the information) into lines/circles etc editable points
> from one click. I had a look but could not really see if this was
> true for pdf's as well.
Keep in mind that PDF's can contain multiple object types (images,
paths, and text). If you are able to underlay the PDF and snap to
points I expect it contains paths, not an image.
If the PDF contains image(s) I expect that RD would do a wonderful job
on them once extracted, but I don't know that it can extract them.
> Question - If we bought AutoCAD raster design would we be able
> to insert a PDF drawing and turn it into Autocad Data much quicker
> than our current process?
If your current process is underlaying then tracing based on snap
points, then you should try the demo of DotSoft's PdfImport from
http://www.dotsoft.com/pdfimport.htm. This low cost utility will import
paths from PDFs forming polylines in seconds. It will also extract
images and place them as AutoCAD images.
Feel free to email me at dotson [at] dotsoft [dot] com.
Terry
Never start any job without the right tools!
AutoCAD Add-on Tools at http://www.dotsoft.com
