AutoCAD Raster Design Forum
Raster Design COM Reference in 64 bit 2012
0 REPLIES 0
Message 1 of 1
will.crichton
643 Views, 0 Replies
I am having issues with the Raster Design reference in my 64 bit .NET application...
The reference in not getting imported as 64 bit. I have experimented with a number of options for defining the reference but it always comes in as 32 bit.
I have tried defining the reference as COM.
When I browse the results in the Object Browser it shows the incorrect type of int for a number of critical object Id properties:
I have also tried to create the Raster Design reference using the following techniques:
  • browsing to the C:\Program Files\Common Files\Autodesk Shared\AeciIbCom.tlb file directly
  • building an assembly using tlbimp and the /machine:X64 switch and browsing to the resulting .dll
These both resulted in the same issue.
However if I use VS to view the tlb file directly in the object browser it shows the correct type for the object Id properties:
Drag and Drop C:\Program Files\Common Files\Autodesk Shared\AeciIbCom.tlb into VS.
Does anyone out there have a solution as to how to get the 64 bit Raster Design type library referenced correctly.
0 REPLIES 0
”Boost
