AutoCAD Raster Design General Discussion
Valued Mentor
awood
Message 1 of 10 (2,764 Views)
Raster Design 2013 and MrSID Generation 4
2764 Views, 9 Replies
04-05-2012 10:22 AM
Does anyone know if Raster Design 2013 will support the fairly new MrSID Generation 4 (mg4) imagery?
AWood
DMillerAmCan
Message 2 of 10 (2,746 Views)
Re: Raster Design 2013 and MrSID Generation 4
04-11-2012 01:54 PM in reply to: awood
Not Sure but my Raster Design 2013 crashes when I try to load a MrSID
DMillerAmCan
Message 3 of 10 (2,731 Views)
04-16-2012 11:51 AM in reply to: awood
Its been a week now and Autodesk still has no answer why Raster Design 2013 Crashes when trying to open a MrSID
DMillerAmCan
Message 4 of 10 (2,690 Views)
05-01-2012 03:03 PM in reply to: DMillerAmCan
Its now been 2 weeks. Autodesk development is looking into why my system Crashes when I "ADD" or attempt to add imagery (in .sid) through the Map Work Space interface. I am running Raster Design 2013 and it wont open a stand alone copy of any of my new MrSID Files. Possible may be due to the 4th Band CIR (infra Red). Still waiting and not working
Valued Contributor
derek.gray
Message 5 of 10 (2,080 Views)
11-20-2012 06:32 AM in reply to: DMillerAmCan
I am also looking for supported generations (4) of MrSid in Raster2013... I would think that should be easy to find out.. not so much it seems....
Valued Mentor
Hidden_Brain
Message 6 of 10 (1,124 Views)
09-03-2013 09:27 AM in reply to: derek.gray
was there any resolution to this?
thanks
Avishek Chhibber, P.E., CFM
Civil 3D 2013 SP2, Win 7-64 bit
8GB RAM
Valued Contributor
derek.gray
Message 7 of 10 (1,123 Views)
09-03-2013 09:35 AM in reply to: Hidden_Brain
I worked around it by using Lizardtech's Geoviewer to save them as tiff's... not ideal, but it worked for my issue...
Member
DeannaSkraba8194
Message 8 of 10 (679 Views)
12-13-2013 07:21 AM in reply to: DMillerAmCan
Good morning!
Has anyone gotten an update from Autodesk regarding a fix for this? We just received our new imagery in the MrSID Gen4 format and all my online research is point me to this thread.
Thank you!
Deanna
DMillerAmCan
Message 9 of 10 (673 Views)
12-13-2013 10:14 AM in reply to: DMillerAmCan
Not to my knowledge
David Miller
ENGINEERING
[cid:image001.png@01CEF7EC.08EE98C0]
4381 Broadway, Suite 201
American Canyon, CA 94503
707.647.4576 Office
707.643.2389 FAX
dmiller@cityofamericancanyon.org
http://www.cityofamericancanyon.org
Active Contributor
dnietubicz
Message 10 of 10 (130 Views)
07-21-2014 01:42 PM in reply to: DMillerAmCan
autodesk doesn't support mr sid Generation 4 images. see this topic.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/2013-mrsid-image-fix/td-p/5015864
New AutoCAD Raster Design Category!
The AutoCAD Raster Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
