AutoCAD Raster Design General Discussion
Valued Mentor
parkr4st
Message 11 of 18 (1,882 Views)
Re: Raster Design 2012
05-24-2011 05:15 AM in reply to: snakerancher
RD 2012 arrived via download this a.m.  loaded it up.  so far won't iinsert a 25066 kb MrSid without crashing Map3D 2012 and after using mapiinsert command to load the sid I tried to save the image to jpg. it crashed at 54% saved.  SOSDD!
dave
Distinguished Contributor
snakerancher
Message 12 of 18 (1,881 Views)
05-24-2011 05:55 AM in reply to: parkr4st
Dave, I loaded a 2MB JP2 with no problem using raster. I usually use the data connect to attach image files. Not sure what the issue is, what are your machine specs?
Member
mohl
Message 13 of 18 (1,845 Views)
05-25-2011 12:26 PM in reply to: snakerancher
Has anyone tried to build a 64 bit deployment package for Raster Design 2012?  I get to the point where I enter the configuration name, Admin image path, target platform and installation settings.  As soon as I have them set, I click on Next and get the error "Error 1723.  There is a problem with this Windows Installer package.  A DLL required for this install to complete could not be run.  Contact your support personnel or package vendor."  After I click OK to the message, I get "Fatal error during installation.  #2178: failed to run AdskExecuteSequence.".  Clicking OK to that error gives me "Failed to initialize AutoCAD Raster Design 2012".  After these 3 errors, it takes me back to the configuration screen, but is locked up and I need to use Task manager to kill the process.
Help please?
Member
mohl
Message 14 of 18 (1,844 Views)
05-25-2011 12:28 PM in reply to: mohl
In addition to the above post, I tried to re-download the raster package and ended up with the same result.  The 32 bit version builds without issue.
I've been building these packages on a Windows 7 32 bit PC and my 64 bit versions of AutoCAD, Map3D and LT all built without issue.
Valued Mentor
parkr4st
Message 15 of 18 (1,838 Views)
05-25-2011 01:08 PM in reply to: snakerancher
snakerancher
Processor Intel(R) Pentium(R) D  CPU 2.66GHz, 2654 Mhz, 2 Core(s), 2 Logical Processor(s)  32 bit
ATI Firepro V5800(FireGL) video w/3 monitors
redundant 1t HDs
4 GB ram/3 available to Map3d
 WIN 7 PRo  SP 1
Map3d2012
RD2012
dave
jmayo
Message 16 of 18 (1,749 Views)
06-02-2011 12:25 PM in reply to: mohl
I get the same behaivor. I can build a 32 bit deployment but not a 64 bit. I get the same FE #2178.
John Mayo, PE
IDSP 2014
Win 7 64, Xeon ES165@3.2Ghz,
64 GB RAM, Quadro K4000 (x2)
jmayo
Message 17 of 18 (1,683 Views)
06-08-2011 09:17 AM in reply to: mohl
You cannot create a 64 bit deployment from a 32 bit machine. Run setup from a 64 bit client (Run as Administrator) and save the deployment to the network location of your choice.
This tip came from Subscription Support and I am up and running.
John Mayo, PE
IDSP 2014
New Member
ESTHERAGUIAR6309
Message 18 of 18 (902 Views)
Raster Design 2012
04-22-2013 06:19 AM in reply to: snakerancher
Trabalho com imagens de projeto de ruas na prefeitura municipal de curitiba. Separo em camadas preto e vermelha. A camada preta nunca mudo por isso fica com o cadeado fechado. A camada vermelha é a que preciso vetorizar, apagar. Mas quando uso a ferramenta "remove", fica uma mancha preta. Sempre deu certo, mas desde que foi feita atualização para o Rasterdesign 2012, não consigo apagar a imagem sem aparecer esta mancha. Segue um anexo com o problema. Desde já agradeço a ajuda.
New AutoCAD Raster Design Category!
The AutoCAD Raster Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
