Solved by parkr4st. Go to Solution.
Solved by Ahatz. Go to Solution.
Those who know...
It was released last year on Jul 18 09 as per my Subscription page. I do believe that was a late release date for the product. 2009 was released on April 20 08 so hopefully wee'll see it soon.
John Mayo
It really didn't look like there was much of a change from Raster 2010 to 2011 other than Windows 7 support and the ability to run it with the 2011 product series. Does anyone know if Raster 2011 will run with Civil 3D 2012? I haven't tried as of yet.
We use Raster extensively and as such upgrading Civil 3D is pointless until Raster will run along side of it - that meant waiting on last years Civil 3D upgrade 3 months.
There has been one 64 bit version of RD to date, RD 2011. 64 bit Autocad has been out for a few years. A 32 bit version of RD for 64 bit OS's have been previously released.
John Mayo
RD 2012 arrived via download this a.m. loaded it up. so far won't iinsert a 25066 kb MrSid without crashing Map3D 2012 and after using mapiinsert command to load the sid I tried to save the image to jpg. it crashed at 54% saved. SOSDD!
dave
Has anyone tried to build a 64 bit deployment package for Raster Design 2012? I get to the point where I enter the configuration name, Admin image path, target platform and installation settings. As soon as I have them set, I click on Next and get the error "Error 1723. There is a problem with this Windows Installer package. A DLL required for this install to complete could not be run. Contact your support personnel or package vendor." After I click OK to the message, I get "Fatal error during installation. #2178: failed to run AdskExecuteSequence.". Clicking OK to that error gives me "Failed to initialize AutoCAD Raster Design 2012". After these 3 errors, it takes me back to the configuration screen, but is locked up and I need to use Task manager to kill the process.
Help please?
In addition to the above post, I tried to re-download the raster package and ended up with the same result. The 32 bit version builds without issue.
I've been building these packages on a Windows 7 32 bit PC and my 64 bit versions of AutoCAD, Map3D and LT all built without issue.
snakerancher
Processor Intel(R) Pentium(R) D CPU 2.66GHz, 2654 Mhz, 2 Core(s), 2 Logical Processor(s) 32 bit
ATI Firepro V5800(FireGL) video w/3 monitors
redundant 1t HDs
4 GB ram/3 available to Map3d
WIN 7 PRo SP 1
Map3d2012
RD2012
dave
You cannot create a 64 bit deployment from a 32 bit machine. Run setup from a 64 bit client (Run as Administrator) and save the deployment to the network location of your choice.
This tip came from Subscription Support and I am up and running.
John Mayo
Trabalho com imagens de projeto de ruas na prefeitura municipal de curitiba. Separo em camadas preto e vermelha. A camada preta nunca mudo por isso fica com o cadeado fechado. A camada vermelha é a que preciso vetorizar, apagar. Mas quando uso a ferramenta "remove", fica uma mancha preta. Sempre deu certo, mas desde que foi feita atualização para o Rasterdesign 2012, não consigo apagar a imagem sem aparecer esta mancha. Segue um anexo com o problema. Desde já agradeço a ajuda.
