Anybody else having similar problems? I installed RD 2010 and when I went to use it, it could not find acdb17.dll. I uninstalled RD 2009, then it worked. I tried out the new program and I found that when I used the deskew the program would crop my image frame. 2009 did not do this. I do not want my images to be cropped, just deskewed. Another issue I am having is that after editing an image I will use the save image as and try to overwrite the existing file. 2010 has an error writing to the file. If you save as a new name or in another directory, detach the image from the drawing, then use windows explorer to copy the new image and paste to the original, you get an error message that says the file is in use. I found that you have to close the drawing and/or reboot the computer in order to accomplish the task. These issues did not happen in releases 2007, 2008, or 2009. From what I have found in one day's use of RD 2010 it is counterproductive.
