AutoCAD Raster Design General Discussion
Distinguished Contributor
Jroper
Message 1 of 1 (680 Views)
Raster 2011 file search path and menus
680 Views, 0 Replies
01-23-2013 04:33 PM
I’m having a weird issue with the File Support Search Path and Raster 2011 and different profiles.  When I launch Raster on a user machine it will not load menus.
 That is because the search path in this particular profile is set to:
C:\users\<user name>\Appdata\Roaming…etc.
The only way to fix it is to switch to a profile that has the path set to:
C:\users\Administrator\Appdata\Roaming…etc.
That is where the AecCo.cuix menu is installed.
I could have sworn it was the user’s roamable root that is configured for the menu.  Is the Administrator's path correct?  If not, how do I set it correctly?
New AutoCAD Raster Design Category!
The AutoCAD Raster Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
