Link is broken. Here is the contents and the solution (apparently, you can only have Raster Design work for EITHER 64 bit installs (autocad, map, etc.) OR 32-bit installs (civil 3d). You have to pick one.
-Anton
Published date: 2009-Dec-15
Applies to:
AutoCADĀ® Civil 3DĀ® 2010
AutoCADĀ® Civil 3DĀ® 2009
AutoCADĀ® Land Desktop 2009
AutoCADĀ® Map 3D 2009
AutoCAD Raster Design 2009
You installed a 32-bit version of AutoCADĀ® 2009 or 2010 or other AutoCAD vertical product, such as AutoCADĀ® Map 3D 2009, AutoCADĀ® Civil 3DĀ® 2009, or AutoCADĀ® Civil 3DĀ® 2010, on your 64-bit operating system. However, when you tried to install AutoCAD Raster Design 2009 or 2010 and link it with these products, you received the following error message:
No supported desktops for AutoCAD Raster Design 2009 were found...
Please Exit and Install a supported desktop before proceeding.
This error message indicates that the installer was not able to find a 64-bit application.
To correct this issue, you need to redirect the installer to look for 32-bit applications on the 64-bit operating system. Follow these steps:
Copy the entire contents of the installation disk to a folder on the hard drive.
In the root of this folder, locate the Setup.ini file and open it with MicrosoftĀ® Notepad.
Under [SETUP], modify the line below as follows:
Old line: x64_IMAGE_PATH=x64
New line: x64_IMAGE_PATH=x86
Save and close the Setup.ini file.
In the root of this folder, run the Setup.exe file.
Note: The following is a known feature limitation of AutoCADĀ® Map 3D 2009 on 64-bit operating systems:
The Map Image Insert command (MAPIINSERT) does not work.
Anton Flewelling
CAD Manager
