I'm unable to edit a raster file in ACAD 2014, and get the following message:
"AutoCAD Raster Design cannot edit an image with different X and Y scales".
I've attached the file using the wizard and accept the default x and y scales?
Is this a bug in 2014? I can send the file to a friend that runs 2011, and he can edit.
Any help apprecaited.
Mark
I know of 2 different sources of the problem and 2 solutions for it.
1. Actual XY scale problem: You need to rubber sheet to correct.
2. Non actual XY scale problem: Raster Design may diagnose the problem as an XY scale problem but its not, instead what is happening is a problem with your user profile. To solve the issue, go to Options > profile > and set to unnamed. If you don't have a profile then create one and se it to your default. You may have to switch back and forward between profiles to make sure your cuiload actually loads all your customisations.
