AutoCAD Raster Design Forum
"AutoCAD Raster Design cannot edit an image with different X and Y scales"
2 REPLIES 2
3136 Views, 2 Replies
I'm  unable to edit a raster file in ACAD 2014, and get the following message:
"AutoCAD Raster Design cannot edit an image with different X and Y scales".
I've attached the file using the wizard and accept the default x and y scales?
Is this a bug in 2014? I can send the file to a friend that runs 2011, and he can edit.
Any help apprecaited.
Mark
2 REPLIES 2
Have you tried Insert = Raster Image Reference?
cramirodi
I know of 2 different sources of the problem and 2 solutions for it.
1. Actual XY scale problem: You need to rubber sheet to correct.
2. Non actual XY scale problem: Raster Design may diagnose the problem as an XY scale problem but its not, instead what is happening is a problem with your user profile. To solve the issue, go to Options > profile > and set to unnamed. If you don't have a profile then create one and se it to your default. You may have to switch back and forward between profiles to make sure your cuiload actually loads all your customisations.
”Boost
