style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<There
href="mailto:severner@co.trumbull.oh.us">severner@co.trumbull.oh.us>
wrote in message
href="news:6081763@discussion.autodesk.com">news:6081763@discussion.autodesk.com...
are multiple problems in our office in regards to Raster Design, versions 2008
and versions 2009. One of us out of the three actually could NEVER use Raster
2008 and had to revert back to Raster version 2007. Our office is currently
working on version 2009. The first problem is that the command "IINSERT" has
not worked in the previous versions for one or two of us out of the three
using the program. If we try to insert a drawing into Autocad that is a TIF
file we get an error, that is stated as follows. IINSERT command
Error:c:\program files\autocad raster design 2009\AeciUi51.ARX ; cannot find a
procedure that it needs. unknown command "IINSERT". Also, when it directs you
to F1 (help) it just directs you to a discussion group to get an answer, which
has just sent us in a loop. The second problem is that we can't two out of the
three of us can't view aerials since we have been working on version 2009. The
third problem is that the same two out of the three that can't view aerials
have a problem viewing blocks that have been established since I believe
release 14. It's not any one certain drawing that we had a problem with it is
basically every drawing. We can see the block on our screen in the drawing but
it doesn't actually exist in the drawing. If you were to click on it the block
will disappear. If you try to insert the block back into the drawing it shows
it in the files to choose from but it is not able to be inserted. There are
other blocks that we are able to use and see, some of those blocks were
established near the same time as the ones that we can't see. We have asked
for help in the past via phone and via e-mail and are getting NO response,
even from where we purchased the product. PLEASE can someone help us out.
Thank You! Edited by: severner@co.trumbull.oh.us on Dec 1, 2008 7:33
PM
<There
wrote in message
PM
"wfb" <
href="mailto:wfberry@bellsouth.net">wfberry@bellsouth.net> wrote in
message
href="news:6085214@discussion.autodesk.com">news:6085214@discussion.autodesk.com...
The Master Guru, Murph is probably recovering
from Jet Lag as we speak. It has been about 3 days since I attended his
seminar and one of the things that I remembered from his seminar is
this:
Make sure you load up Raster D
face=Arial size=2>esign BEFORE you load your drawing or image files.
This will allow the internal programs to have enough memory to operate and can
page out the file info to the hard drive.
Bill
<There
wrote in message
2008 and versions 2009. One of us out of the three actually could NEVER use
Raster 2008 and had to revert back to Raster version 2007. Our office is
currently working on version 2009. The first problem is that the command
"IINSERT" has not worked in the previous versions for one or two of us out
of the three using the program. If we try to insert a drawing into Autocad
that is a TIF file we get an error, that is stated as follows. IINSERT
command Error:c:\program files\autocad raster design 2009\AeciUi51.ARX ;
cannot find a procedure that it needs. unknown command "IINSERT". Also, when
it directs you to F1 (help) it just directs you to a discussion group to get
an answer, which has just sent us in a loop. The second problem is that we
can't two out of the three of us can't view aerials since we have been
working on version 2009. The third problem is that the same two out of the
three that can't view aerials have a problem viewing blocks that have been
established since I believe release 14. It's not any one certain drawing
that we had a problem with it is basically every drawing. We can see the
block on our screen in the drawing but it doesn't actually exist in the
drawing. If you were to click on it the block will disappear. If you try to
insert the block back into the drawing it shows it in the files to choose
from but it is not able to be inserted. There are other blocks that we are
able to use and see, some of those blocks were established near the same
time as the ones that we can't see. We have asked for help in the past via
phone and via e-mail and are getting NO response, even from where we
purchased the product. PLEASE can someone help us out. Thank You! Edited by:
PM
"trumorris" wrote in messageI
href="news:6119549@discussion.autodesk.com">news:6119549@discussion.autodesk.com...
am having the same problem with the INSERT command ... insert a drawing into
Autocad that is a TIF file we get an error, that is stated as follows. IINSERT
cannot find a procedure that it needs. unknown command "IINSERT". If anyone
can help, please let me know what I can do. Thx
