AutoCAD Raster Design General Discussion
New Member
kenneth.kuhner
Message 1 of 6 (407 Views)
Missing IINSERT Command
407 Views, 5 Replies
02-19-2014 07:45 AM
installed raster 2014.   raster tab, insert, gives error
c:\program files\autodesk\autocad raster design 2014\aeciibui57.arx cannot find a dll or other file that it needs.
already changed the current user reg keys but still not working.
what gives?
New Member
kenneth.kuhner
Message 2 of 6 (400 Views)
Re: Missing IINSERT Command
02-19-2014 08:21 AM in reply to: kenneth.kuhner
windows 7 64 bit by the way.
Valued Contributor
jedenton
Message 3 of 6 (336 Views)
03-11-2014 10:40 AM in reply to: kenneth.kuhner
is that the only command not working?
Member
acad
Message 4 of 6 (229 Views)
04-28-2014 10:01 AM in reply to: kenneth.kuhner
Has anyone figured this out - I have the same problem.  It's not just the raster tools "iinsert" command but all the raster tools.  The directories for raster tools and path exists for the command back to the aeciibui57.arx file but it's saying it can't find a needed dll file.
Valued Contributor
jedenton
Message 5 of 6 (226 Views)
04-28-2014 10:28 AM in reply to: kenneth.kuhner
Check to see if your Raster Design path is mapped in the Working Support File Search Path. Go to Options, Files tab, Working Support File Search Path, browse to Raster Design and add, also add RD help. This worked for me.
Member
acad
Message 6 of 6 (214 Views)
04-28-2014 08:20 PM in reply to: jedenton
Thanks for the response. I came across a Autodesk Knowledge base article concerning this problem. It said to basically uninstall / reinstall everything. I had just
loaded it so it was no loss starting over. Everything is working fine with the new install.
New AutoCAD Raster Design Category!
The AutoCAD Raster Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
