AutoCAD Raster Design Forum
Missing AeciIb54.dbx
6 REPLIES 6
AllenJessup
5656 Views, 6 Replies
I installed C3D & RD 2011 a few weeks ago. I hadn't had a reason to use RD until today. When I try to start RD I get an error stating that the program can't start because the file AeciIb54.dbx is missing from the computer. A search finds the file in 3 places:
C:\autodesk\AutoCAD_Raster_Design_2011_Win_32-64bit\x64\Program Files\Raster Design 2011 OE
C:\autodesk\AutoCAD_Raster_Design_2011_Win_32-64bit\x86\Program Files\Raster Design 2011 OE
C:\Program Files\Autodesk\Raster Design 2011 OE
All in the OE installation. Can I copy on of the files from an OE path to somewhere in the OE path or do I need to reinstall RD?
OS is Win 7 64 bit
Allen
A repair changes the message to "Can not fine resource string number 14053 in resouce AeciIb54".
Allen Jessup
CAD Manager - Designer
6 REPLIES 6
It sounds like you are missing Support File Search Paths for Raster Design 2011. They are:
  • C:\Program Files\Autodesk\Raster Design 2011 OE
  • C:\Users\%username%\AppData\Roaming\Autodesk\ARD2011\R18.1\enu\Support
  • C:\Program Files\Autodesk\AutoCAD Raster Design 2011
  • C:\Program Files\Autodesk\AutoCAD Raster Design 2011\Help
Check your AutoCAD options and add those that are missing.
Douglas Lauritsen
Support Specialist
Product Support
Autodesk, Inc.
Sounded good but when I check plain AutoCAD and C3D the paths are already present. I've tried starting from the desktop icon and from the Start menu with no luck
I've found out that I can access RD from Civil 3D. So I just can't start RD on plain AutoCAD.
Thanks.
Allen
Allen Jessup
Make sure the installing user has permissions for
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R18.1\ACAD-9001:***
then try a repair or reinstall install from “Add and Remove Programs” or “Programs and Features.”
Where *** is a 3 digit language code.
Douglas Lauritsen
Support Specialist
Product Support
Autodesk, Inc.
I have an Administrator account and have fill permissions to the key and subkeys. I've tries repair a couple of times with results as mentioned. Since I can use RD in Civil 3D I haven't done a reinstall yet.
The installation and repairs were done from a network deployment. I created the deployment solely for myself, since I'm the only one with a 64 bit system so far. I don't know whether I want to do a reinstall yet because I can use RD now and there is a chance that I'd lose that too.
I do find it strange that I don't get any errors when starting Civil CD or using RD from within Civil.
Thanks for your suggestions.
Allen
Allen Jessup
Rainman1
in reply to: AllenJessup
I am getting this same problem but when someone else logs onto the system Raster Design 2011 (network) runs fine. Also, if I log onto a different system Raster Design 2011 (network) runs fine. Has anyone found a solution to this problem? I have done a total reinstall and still get the same message?????
in reply to: Rainman1
Has this issue ever been figured out? I know the chain of messages is a few years old now, but I just installed Raster Design 2011 for a user and got the exact same message, and this page is the only one that came up when I did a google search.
”Boost
