style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"cwhecker" <First
href="mailto:charles.w.hecker@exxonmobil.com">charles.w.hecker@exxonmobil.com>
wrote in message
href="news:f184691.-1@WebX.maYIadrTaRb">news:f184691.-1@WebX.maYIadrTaRb...
off, I am new to Raster Design and AutoCad.
We selected Raster Design since it could handle grayscale (8-bit) images.
We have many existing drawings that could not be scanned as 1-bit since we
would lose so much data.
I can open the 8-bit, grayscale jpg file in Raster Design just fine. In
some cases we will add text or lines and then convert the vector to raster and
keep just the jpg file as a single file.
Other times, we will need to create hybrid files; having both a vector
(dwg) and raster (jpg) images.
This is where the question comes in....
If I want to delete a portion of the jpg file that will be replaced with
new work or simply left blank, I am using Image-Remove-Rectangular Region.
After selecting the region to be deleted, what appears is a black region in
the middle of my grayscale image where there once was the piece I removed.
When I print this, I get just that; a black region in the middle of my image.
I used the BACKGROUND command line option and tried to change the
background to white, but this did not solve the problem.
How can I make
the region I delete from the jpg image not appear as a black section on the
drawing?
Also, if you can give me any other advice about working with the jpg
drawings I would appreciate it.
Thanks for your time,
Charles
"cwhecker" <First
wrote in message
How can I make
drawing?
Charles
