AutoCAD Raster Design General Discussion
Valued Contributor
davidm
Message 1 of 4 (4,206 Views)
Accepted Solution
Image tab does not show up on ribbon
4206 Views, 3 Replies
07-28-2010 02:53 PM
I installed raster 2011 and start Architecture using the RD for Architecture shortcut and there is no IMAGE tab in the ribbon. How do I get to the RD tools?
DouglasLauritsen
Message 2 of 4 (4,197 Views)
Re: Image tab does not show up on ribbon
07-29-2010 09:50 AM in reply to: davidm
First off you might be like me and have to translate many years of using “Image” for the Menu or Ribbon tab name to “Raster Tools.“ It is now "Raster" for the Menubar and "Raster Tools" for the Ribbon.
Next double check that you have a Workspace loaded.
Then check that the Partial CUI for AutoCAD Raster Design 2011 is loaded:
   Vista and Windows 7: C:\Users\%username%\AppData\Roaming\Autodesk\ARD2011\R18.1\enu\Support\AecCo.cuix
   XP: C:\Documents and Settings\%username%\Application Data\Autodesk\ARD2010\R18.0\enu\Support\AecCo.cuix
AutoCAD Raster Design 2011 also requires these additional Support File Search Paths:
   C:\program files\autodesk\raster design 2011 oe
   A user profile folder:
           XP: C:\Documents and Settings\%username%\Application Data\Autodesk\ARD2011\R18.1\enu\Support
   C:\program files\autodesk\autocad raster design 2011
   C:\program files\autodesk\autocad raster design 2011\help
Let us know how things work out.
Douglas Lauritsen
Support Specialist
Product Support
Autodesk, Inc.
Valued Contributor
davidm
Message 3 of 4 (4,195 Views)
07-29-2010 11:06 AM in reply to: DouglasLauritsen
Yea, Raster tools, that's what I meant to say :smileywink:
Checked under workspaces, something I never use (for lack of understanding it) but found two workspaces. Architecture (checked) and Architecture - migrated from 2010. I checked the latter and sure enough there they were. Thanks much, now I need to learn about workspaces.
Distinguished Contributor
snakerancher
Message 4 of 4 (4,185 Views)
07-30-2010 09:01 AM in reply to: davidm
I noticed that happening to all my 2011 Raster installs.  Try and repair the install, Raster Tab should show up.
Announcements
Need installation help?
New AutoCAD Raster Design Category!
The AutoCAD Raster Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
