Show only
Search instead for
MapGuide Enterprise 2009 does not appear to support JP2 files (while Map does). Therefore I need to convert the georeferenced images to another format. Is this possible with raster design?
Thansk - that shows how much I've used RD in the past! I exported JP2's as TIFFs, and using JPEG compression the file size was only doubled, which is acceptable (15x with LZW!).
