I think it's in the readme or help file somewhere:
The default setting is the optimal memory setting. It automatically
calculates how much memory is available and how much to use.
The memory setting is really only for limiting the amount of memory
used. It cannot now be increased over the optimal setting (as opposed
to older versions where that setting was actually used to increase the
memory usage).
On Tue, 10 Jun 2008 14:56:21 +0000, ErnestBesse <> wrote:
>Phil,
>I have 4Gb of RAM, and also have 1Tb HD with a temp folder that has a 4GB pagefile allocated for AutoCAD Raster Design to utilize. However, on the Image Options "memory" tab - AutoCAD only shows 2048 Mb - and does not allow me to set the memory above 50 Mb. When I had Raster Design 3 for AutoCAD 2002, I was allowed to set the memory at 2Gb. Why won't AutoCAD Raster Design 2006 allow me to set the memory under Image Options higher than 50 Mb?
Phil Daley
