Here's a suggestion based on similar glitches i've had in the past.
If the image is inserting with the proper geo-reference but color is forced to grayscale, then
1. export a world file,
2. detach the image,
3. MAKE A BACKUP OF THE IMAGE(s)
4. open the image in some other raster editor
(Photoshop, GIMP; anything able to open and "save as" a file of this size)
5. do a "Save As" to overwrite the image
(generally, this is removing any fancy headers embedded in the file, which can -for whatever reason- cause AutoCAD to display grayscale)
6. insert the image into AutoCAD, but you'll need to use the World file since the header has been stripped out.
(7) if you want/need, you can now export a new image from AutoCAD with the geo-ref header embedded.
hope that helps
it's a few hoops to jump thru, but it worked for us.
matt
Edited by: m4tts1m on Apr 21, 2009 2:09 PM
Edited by: m4tts1m on Apr 21, 2009 2:10 PM
