AutoCAD Raster Design General Discussion
randcdavidson
Message 1 of 2 (726 Views)
Going to need that hotfix for shift select RD 2011
726 Views, 1 Replies
07-26-2010 02:42 PM
We had this same issue with 2008 or was it 2009 RD. Deselecting "Shift plus left click" to select image in options does not work. I can't shift select anything in regular Civil3D without it forcing me to select the image underlay.
DouglasLauritsen
Message 2 of 2 (707 Views)
Re: Going to need that hotfix for shift select RD 2011
07-28-2010 11:37 AM in reply to: randcdavidson
I believe you are using MAPIOPTIONS to clear the “Shift+Left Click Image Select” check mark on the General tab. If you have installed AutoCAD Raster Design the similar setting in IOPTIONS overrides it. You will therefore want to clear the “Shift+Left click image select” checkmark from the User Preferences tab in IOPTIONS.
Douglas Lauritsen
Support Specialist
Product Support
Autodesk, Inc.
Need installation help?
New AutoCAD Raster Design Category!
The AutoCAD Raster Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
