I have an engineer who is running into trouble with printing a multi-sheet drawing in Raster Design. It print's absolutely fine under AutoCAD 2006 but when it's opened up in Raster Design I keep getting a FATAL ERROR: Out of memory message. Doesn't do it for all the drawings. It must be quite a large file but there is 8GBs of RAM on the PC (64-bit, Windows XP) so not sure how it could possibly be that large for it to do that but I am also not an engineer. Is there a patch or a hotfix that I can download that may fix this issue. Thank you!
