AutoCAD Raster Design Forum
Error in Raster Design 2004 w/ ADT4
1 REPLY 1
416 Views, 1 Reply
I'm getting an error when I try to run Raster Design 2004 in ADT4.0 or
Acad2004. Basically when I type the "Image" command, I get a message
stating: "ISM Context Menus did not load". When I manually load the
AECO.mnu (Raster design menu), none of the arx functions for raster design
works and I then get an Exception 1F error loading the raster design arx
file such as AECIREMU140.arx etc..
Any ideas? I've uninstalled/re-installed ADT40, ACAD2004, and Rasterdesign
2004 and still get this problem.
thanks,
Doug
1 REPLY 1
Hi Doug,
Try the suggestion in the following solution:
TS63658 - Autodesk® CAD Overlay® 2000i software terminates unexpectedly
during startup
http://usa.autodesk.com/getdoc/id=TS63658
Jonathan Golubiewski
Autodesk Professional Services
Land.Civil.Survey
"Doug Cochran" wrote in message
news:00281093237715675A4963EB25405000@in.WebX.maYIadrTaRb...
> thanks,
> Doug
”Boost
