On the Transform tab, select "3 point affine" as the Transform type.
That is equivalent to the old behavior.
ECW files are now editable in RD2008, which means you are
allowed to do a "True (pixel by pixel)" transform. For a large
ECW, that is not practical or desirable (even if you had enough
memory to perform the transform, you'd have to save the result
to a new image).
Matt
"R.K. McSwain" wrote in message
news:5770359@discussion.autodesk.com...
Using AutoCAD Land Companion Enabled Map 2008, and Raster
Design 2008, I use the ._IINSERT command from Raster Design
to insert and transform (from UTM83-14 to TX83-SCF) an .ECW
image and AutoCAD just hangs up. You have to use the Task
Manager to end the task.
Repeat the same thing using the 2006 versions of these
applications and the same image inserts almost instantly.
In 2008, if you do not transform the image, it works just
fine also.
R.K. McSwain
http://rkmcswain.blogspot.com
