AutoCAD Raster Design General Discussion
*Kalman, Albert
Message 1 of 3 (283 Views)
Does "burn in rotation" alter the color space?
283 Views, 2 Replies
10-06-2003 04:22 AM
I found the little bug ?
I have a 256 color scaned map. It is georeferenced with rotation.
1. I made a crop and save it with export without burn in rotation.
2. I converted tot grayscale via histograms and I exported it without burn
in rotation.
3. I checked the file with ACDSee and I got properties colo:256 grayscale.
OK.
4. I exported again the grayscale image but now with "burn in rotation"
checked.
5. I checked file with ACDSee and I got properties color: 256 !!! ?
Now, I try to put them in the same ric (MG Raster Workshop), I got below
error message.
"The color space of image : ... path xxx.tif does not match that of the
first file referenced by the raster image catalog."
Thanks!
Raster Desgin R3.
Albert Kalman
*Daley, Phil
Message 2 of 3 (283 Views)
Re: Does "burn in rotation" alter the color space?
10-07-2003 01:39 AM in reply to: *Kalman, Albert
On Mon, 6 Oct 2003 12:22:32 -0700, "Albert Kalman"
>in rotation.
>OK.
>checked.
No.
I tried this on Raster Design 2004.
1. I inserted SanFran.tif (from the samples dir).
2. I used Histogram to convert to grayscale.
3. I exported the image to orig.tif
4. I rotated the image.
5. I exported with burn in rotation to new.tif.
6. I inserted both images into AutoCAD.
In Tools->Properties, both images are listed as grayscale.
I loaded both images into Paint Shop Pro. Both images are grayscale.
Phil Daley
*Kalman, Albert
Message 3 of 3 (283 Views)
Re:
10-10-2003 01:54 AM in reply to: *Kalman, Albert
Please try with Raster Design R3 (Autodesk Map Series R5), Check with ACDSee
and try to make a ric for MG. As I found the problem.
I can post the 2 sample on customer file.
Thanks!
Albert Kalman
"Phil Daley" wrote in message
news:apq5ovov96bgdon24lru2i5ca4hju0n6pv@4ax.com...
burn
> >in rotation.
grayscale.
> >OK.
> >checked.
> No.
> Phil Daley
New AutoCAD Raster Design Category!
The AutoCAD Raster Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
