AutoCAD Raster Design Forum
Message 1 of 9
3278 Views, 8 Replies
Deselect
For some reason whenever i load ARD into AutoCAD i can no longer shift+left
click to deselect items in ACAD. Ive had this problem since ARD 2006. Anyone
else have this problem?
Mike
8 REPLIES 8
Message 2 of 9
I have isolated the problem to the file AECiUi51.arx, whenever this file is
loaded i can no longer use my shift+click to deselect items.....
"Mike" wrote in message
news:5616506@discussion.autodesk.com...
Mike
Message 3 of 9
IOPTIONS.
User Preferences tab, under Mouse Settings; uncheck "Shift-Left click image
select".
Matt
Mike
Message 4 of 9
Of course it had to be something easy and stupid on my part. Who in their
right minds would bother checking all the options..... 😞
Mike
"Matt Osborn" wrote in message
news:5616538@discussion.autodesk.com...
IOPTIONS.
select".
Matt
Mike
Message 5 of 9
Don't feel bad. I found out because I talked to an Autodesk employee & was grumbling about it then he told me how to fix it. I had been using RD for 3 or 4 years by that time.
Message 6 of 9
I am having this same issue.... I am running A.cad LT2008 on a Parallels Mac program...
Can anyone help!
Message 7 of 9
I tried the above solution and I don't have a mouse options button?
Message 8 of 9
You're not having the same issue, as Raster Design does not even run on LT.
wrote in message news:5828410@discussion.autodesk.com...
Can anyone help!
Message 9 of 9
JeffClark433
It took a long time before I figured out "I(eye)Options".
I didn't know all that was there.
I've been having the same problem for a long time now.
Do enough research, and you can sometimes, find the answer.
”Boost
