I'm encountering a few glitches with Autocad 2004 and the Raster Design software, and I don't know if they are true glitches in the software, or if they are limitations in the Demo version itself.
For example, when I use the text recognition, the font (simplex) that comes in vectorized is not the same that I selected as my standard font (arial). When I check the properties of the text, it indicates arial as my standard font.
Another tool that doesn't work is the clipboard. I select the clipboard, identify the object I want to copy, press enter, then nothing happens. We have a lot of redundant art and it would be great if we could save this art to a clipbook for later use.
I'm experiencing other problems with inconsistent line weights in the vector to raster conversion (I used a fixed pixel width), but I believe the problem is a video card incompatibility issue which I hope to be rectifying shortly.
Thank you for your help!
Dana
