AutoCAD Raster Design Forum
CUI needs to be read/write?
2 REPLIES 2
dgorsman
403 Views, 2 Replies
I have the AecCo.CUI and MNR files for Raster Design 2008 on the network in a read-only folder to prevent users from accidentally or purposely modifying them. However, when I attempt to edit a CUI file that loads it as partial, I get a "file is read-only" warning - a sign that something is being changed.
Is there a requirement that the Raster Design 2008 CUI file needs to be in a read/write location? What is it trying to change?
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
2 REPLIES 2
in reply to: dgorsman
It is warning you that, IF you make changes, you will not be able to
save them.
Phil Daley
dgorsman
I don't get the same warning for other read-only partially loaded CUI's, though.
”Boost
