> Diego Kennedy wrote
>I'm working witch an file in format PDF and I need to know how do I do to
>convert itfor file that I can to work in raster Desing?
If the PDF contains raster images that you want to use, this extraction
utility works well:
http://www.verypdf.com/pdf2tif/index.htm
If the PDF contains a mix of raster and vector entities (and you want them
all together), then you'll need to install a printer driver that allows you
to print to an image file.
Matt
