AutoCAD Raster Design Forum
Convert Pdf to file raster
1 REPLY 1
347 Views, 1 Reply
I'm working witch an file in format PDF and I need to know how do I do to convert itfor file that I can to work in raster Desing?
1 REPLY 1
If the PDF contains raster images that you want to use, this extraction
utility works well:
http://www.verypdf.com/pdf2tif/index.htm
If the PDF contains a mix of raster and vector entities (and you want them
all together), then you'll need to install a printer driver that allows you
to print to an image file.
Matt
”Boost
