AutoCAD Raster Design General Discussion
Active Member
JeffBowlin
Message 1 of 4 (3,070 Views)
Civl 3D and Raster Design Integration.
3070 Views, 3 Replies
04-19-2012 05:20 AM
Win 7, 64bit deployments of each on an application server, each installed on a new computer, Civil 3D first, then Raster Design. User reports that the Raster Design menu/functionality are missing from his Civil 3D GUI. I did not notice anything in building the Raaster deployment build to integrate.
Can anyone help?
wfberry
Message 2 of 4 (3,065 Views)
Re: Civl 3D and Raster Design Integration.
04-20-2012 12:30 PM in reply to: JeffBowlin
There is a separate starting Icon when using Raster.
(Also it is in the Start Menu.)
Bill
sharshbarger
Message 3 of 4 (3,034 Views)
05-09-2012 04:45 AM in reply to: wfberry
This is a known issue when you have 2012 Raster design installed.  In the "readme" file for installation of 2013, it states that if you have 2012 Raster design installed, you must first uninstall it.  Well, I did that and still had the issue.  The Raster desgin 2013 is NOT loading. Its not loading when you select the Raster desgin on Civil 3d icon nor is it loading on the regular Civil 3d.
Obviously its a known issue if it's documented within the installation, but whats the fix?
sharshbarger
Message 4 of 4 (3,020 Views)
05-09-2012 08:30 AM in reply to: sharshbarger
Got the fix.
From the command line, type in cuiload.  The "load/unload Customizations menu pops up.
From there, browse out to "C:\program files\autodesk\raster design 2013\userdatacache\AecCo.cuix" and click open
Then load
Then close
And now you should have the Raster Tools Ribbon shown.
New AutoCAD Raster Design Category!
The AutoCAD Raster Design forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
