style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"gannboa" wrote in messageHello
href="news:6139442@discussion.autodesk.com">news:6139442@discussion.autodesk.com...
to all ! I am using AutoCAD Raster Design to Map I would like to ask if there
is any way to modify some characteristics of an image ? I’m georeferencing
some images, and in the end I make a “crop” from menu image, but although I
cut the image, always appear a rectangle around my cut, that I think is the
“frame” and when I export the image (in this case to .jpeg), it appears with a
black strip all around the image, this images are used to publish in a
application, and as you may imagine … is not very nice to eyes. I already put
the frame above and frame off, but this frame stiil go one the image when is
exported, what can I do ? Thank in advanced Diogo
David
<gannboa> wrote in messageHello
href="news:6140127@discussion.autodesk.com">news:6140127@discussion.autodesk.com...
Murph, tank you for replied my post, but I already try this, the “2” means
frames below, we can see that selecting the image, then properties, tab
General and changing frame setting. Unfortunately it didn’t work, or I’m doing
something wrong …. I worked my image, than I applied a “crop” (by polygonal
region), changed the image frame (tried the “0” and the “2”), exported the
image and when I published the image … there it was … the frame in black (my
display color). If someone have any idea …. Please help Best regards Diogo
David
