Hi Anthony,
We are collecting datasets in the interest of investigating performance
issues.
Would you be willing to post some images that you are having trouble with to
customer files for review and testing? If so, please post the files to
customer files
(news://discussion.autodesk.com/autodesk.autocad.customer-files) and reply
directly to me with the title of the customer files post.
Thank you!
Jonathan Golubiewski
Autodesk Product Support
Land.Civil.Survey
"Jon Golubiewski [Autodesk]" wrote in
message news:41507c81$1_1@newsprd01...
> Hi Anthony,
> >>1. Raster Design performance and display is light years *behind* 2004...
> issues.
> >>2. Repeatable crash: Have image up, change memory amount
> I have been able to recreate this issue. I have logged this issue.
> >>3. Bug: Start Map 3D, invoke a RD command, Map 3D loads...
> We have been able to recreate this issue and we are currently
investigating
> this issue.
> Thank you!
> Land.Civil.Survey
> "Anthony" wrote in message
> news:41116f1d$1_2@newsprd01...
> > In just one day I've discovered a bunch of problems with my copy of
Raster
> > Design 2005. First the configuration...
> > IBM Netvista
> > P4-2.4GHz/533FSB
> > 1GB DDR Ram (PC2100)
> > nVidia GF4 Ti 4200, various driver versions on various computers (2942,
> > 4523, 6177)
> > Autodesk Map 3D 2005
> > Autodesk LDD 2005
> > Autodesk Raster Design 2005
> > Now the problems...
Pan
> > and zoom perform really really bad on my computer, and everyone else's
in
> my
> > work group, in either draft or normal quality. On some images, when I
zoom
> > out, my image nearly disappears, only to reappear when I zoom in, that
> never
> > happened in 2004. The images are bitonal Group 4 TIFFs 36"x24" at
400DPI,
> > the same format we were using under 2004. Color TIFFs (1 sq. mile, 1
pixel
> > 1 foot) peform worse than 2004 as well, though not as bad (I'd suspect a
> > size issue).
> > 2. Repeatable crash: Have image up, change memory amount in RD options,
> > perform a RD command or have RD redraw the image. Autocad product just
> > disappears - no fatal error message box or anything.
> > 3. Bug: Start Map 3D, invoke a RD command, Map 3D loads the RD extension
> > (the splash screen shows up), it works fine. Use any RD commands you'd
> like.
> > But you cant save the images (in our case bitonal TIF). If you start it
> > using the RD icon and it loads it off the bat, you can save images just
> > fine.
> > Waiting eagerly for RD 2005 SP 1, hoping that it fixes my problems,
> > Anthony
